| little prongs push back out and so don't make correct contact. take the plastic cover of the back of the plug and carefully look.. also make sure when you put it back in that you only tighten it as much as required NOT as tight as possible as that can cause it to bow and loose connection. (but it must be bolted) this might help for wiring ... [ http://www.karljapetre.com/z/ecu/ ]
